VPN connection question
14 years 9 months ago #35080
by ardeef
VPN connection question was created by ardeef
Hello!
Can I use or implement VPN even if I don't have website and that I don't have a registered domain name?
I was trying to implement( experimenting actually) VPN on my small network.I had set up remote access and services on my 2003 server and followed the steps in configuring VPN, but still can not connect.
Thank you very much.
- skepticals
- Elite Member
14 years 9 months ago #35097
by skepticals
Replied by skepticals on topic Re: VPN connection question
No, you do not need a website or registered domain name to connect to a VPN. You can use an IP address.
Can you explain your setup and problems?
14 years 9 months ago #35100
by ardeef
Replied by ardeef on topic Re: VPN connection question
For the mean time, I will try harder to make it work. I will re post this same problem If I cant make it.
