5-4-3 rule in ethernet
21 years 10 months ago #345
by jackeen
5-4-3 rule in ethernet was created by jackeen
currently studying for the network +,thanks to this site it is going a lot easier,
one of the questions i have never understood is the 5-4-3 restrictions in ethernet,and how large companies get around them.
say for instance a company 2000 computers
21 years 10 months ago #346
Replied by Chris on topic 5-4-3 rule in ethernet
Jackeen,
The 5-4-3 rule dictates that an ethernet (10 base2, 10base5 or 10BaseT) network can have a maximum of 5 segments, with 4 repeaters and only have upto 3 segments populated.
Let's see how well I can show you this in plain text:
S1----=R=----S2---=R=----S3----=R=---S4---=R=---S5
In the above diagram, the S represents the segment or in plain english, one part of the network. The R is the repeater, e.g a hub.
Assuming we required to setup a silly network like the one above, then we would only be able to populate (put pc's) in segments S1, S3, S5 (3 populated segments MAX.).
Keep inmind that the 5-4-3 rules is applies only for 10base2 (coaxial), 10Base5, and 10baseT (utp) ethernet networks.
These limitations have got to do with the amount of time a signal requires to travel from one host to another, depending on how fat apart they are. If you violate this rule, then you start getting networking connectivity problems.
The 5-4-3 rule was created back when 10base2 and 10base5 were used in networks.
The limitations can easily be overcomed by using switches, because switches work in a very different manner and are not confined to the same limitations Hubs or repeaters have.
There will be a page covering the 5-4-3 rule in the future - its on the list [img]images/smiles/icon_smile.gif[/img]
I hope the above helps clear things for you.
p.s Goodluck with your Network+ - its a easy exam and will definitely teach you a lot about basic networking concepts.
