Configure 1841 router and 2 PCs
14 years 6 months ago #35628 by sais
Here's my step by step: Don't bother about using the CLI and router command, just set this using the GUI interface of Packet Tracer
1. On the router, configure eth 0/0 as 192.168.1.1, set it a default subnet mask of 255.255.255.0.
2. Now add your two hosts, name the first host PC 01, and the second host PC 02
3. Go into PC 01. Set the default gateway as 192.168.1.1, Set the IP adress as 192.168.1.2. Set the subnet mask as 255.255.255.0
4. Go into PC 02. Set the default gateway as 192.168.1.1. Set the IP address as 192.168.1.3. Set the subnet mask as 255.255.255.0
5. Now drag a hub into the setup. Don't bother about it's name, it doesn't matter right now.
6. Now deal with the cabling. You will need straight-through cabling for all your connections because all your connections are DCE-DTE connections i.e.
PC01/PC02 - HUB
HUB - Router
7. for PC01/PC02 to hub connection. use a straight-through copper cable and connect the following
For PC01 : connect the Fast ethernet port on the pc to Port 1 of the hub
For PC02: connect the fast ethernet port on the pc to Port 2 of the hub
8. For hub to router connection, use the straight-through copper cable and connect the following:
Port 0 of hub to eth 0/0 of the router.
Now ping away to glory, you will be able to ping the router from the pc and both pcs from the router.
This is your cheap and cheerful way of doing this.
As a next step you can try implementing the DHCP functionality of the router to set automatic IP adresses.
Once that is achieved, you can replace the hub with a switch, and create more efficient network structure
Let us know how you get along[/list]
can any one help to configure using router in wimax. if small office as 2 320 -wimax cpe. configure router 1841, switch 3950, they want 3 vlan. ie 2 for data vlan, 1 voice vlan.............pls give me config with example
14 years 6 months ago #35629 by sais
PC01/PC02 - HUB
HUB - Router
give example to config router 871 in wimax, for data, voice vlan............
