routing question
16 years 6 months ago #33949 by sam4sg
routing question was created by sam4sg
Here is my typical setup.
PC10 <-> Router11 <-> Router12 <-> Router22 <-> Router21 <-> PC20
PC10 is connected to Router11
Can Ping PC10 from Router11
Router11 and Router12 are running IGRP
Can ping PC10 from Router12
Similarly, from the other end,
PC20 is connected to Router21
Can Ping pc20 from Router21
Router21 and Router22 are running IGRP
Can ping PC20 from Router22
Now,
Router12 and Router22 are running identical OSPF setting:
router ospf 1
log-adjacency-changes
redistribute eigrp 1 metric 66 metric-type 1 subnets
network 200.200.2.0 0.0.0.255 area 0
both router12 and router22 have the similar command.
router 12 and router 22 have these identical IGRP settings:
router eigrp 1
network 200.200.0.0 0.0.0.3
no auto-summary
when I do sh ip route on both routers, I can see all the networks that but when I ping or traeroute, it does not work. It works only from one side., but not from other side.
I tried
redistribute eigrp 1 metric 66 metric-type 1 subnets in one
and redistribute eigrp 1 metric 77 metric-type 1 subnets in another, but still its one sided.
So what am I missing here ?
Sam
16 years 6 months ago #33950 by sam4sg
Replied by sam4sg on topic Re: routing question
solved .
got a bit of reading to do.
Thanks again.
Time to create page: 0.100 seconds
