Regarding switch
15 years 1 month ago #33782
by dat
Regarding switch was created by dat
How to change L2 as L3 switch? what commands needs apply
15 years 1 month ago #33788
Replied by S0lo on topic Re: Regarding switch
A normal L2 switch can NOT work as a L3 switch. However, a L3 switch can work as both L2 or L3 switch.
For example, if you have a Cisco L3 switch such as the 3550, you can enable/disable L3 switching using the ip routing / no ip routing command.
15 years 1 month ago #33804
by Chojin
Replied by Chojin on topic Re: Regarding switch
The switches that support L3 are so called MLS (Multi Layer Switches).
Also your IOS is of importance if your switch can support routing protocols.
You can check the feature navigator of cisco for your switch type.
