Difference between circuit swicthing and PVC
15 years 2 months ago #33383
by freakhead
Difference between circuit swicthing and PVC was created by freakhead
Circuit switching is switching the hardware and dedicating the line through out, where as packet switching is no dedicated hardware.
I think I am missing the basic concept here.
I understand PVC apples for Frame relays for packet switching.
But technically speaking how do they vary? Is it like dedicating a virtual line forever??
But the PVC format goes like DSLAM/SLOT/CARD/PORT right? so how is this virtual? its same as dedicating the whole in right?
15 years 2 months ago #33384
Replied by S0lo on topic Re: Difference between circuit swicthing and PVC
Good question. PVC (Private Virtual Circuit) looks (acts) like a dedicated circuit (line) to the router/DTE devices at both ends. But it's actually implemented using a packet switched network internally. This is where the word "virtual" comes from. So the bandwidth of the network is really shared.
Now you might ask, "If it's actually a shared packet switched, then where is the dedication part?". In-fact, frame-relay kind of simulates a dedicated line by some thing called a Committed Information Rate (CIR). When you buy a PVC, the ISP/vendor promises you a certain CIR (like 1Mbps or 4Mbps, according to the package that you payed for). Frame-relay packet switching has capabilities that can insure you (almost) always get a bandwidth not less than the CIR, possibly more. When there is a congestion in the network, some packets from subscribers that are exceeding their CIR are dropped. At normal or low load times, frame relay tends to allow more than the CIR.
15 years 2 months ago #33386
by freakhead
Replied by freakhead on topic Re: Difference between circuit swicthing and PVC
I think I understood what you said.
The connection from ISP to the router is fixed (DSLAM/SL/CARD/PR). but from here on its not.
In terms of a telco, the E3/E1 links between DSLAM s and aggregators implement the packet form , where multiple O/P ports from DSLAM are connected to same Aggregator port. hence a control can be imposed here over the data flow.
Thanks for that.
Thanks for that.
