3550 questions
16 years 2 months ago #33238 by jdholbrook
3550 questions was created by jdholbrook
I've come upon a problem that needs more smarts that I posses.
I'm the ET (Electronic Tech) here on an oil rig off the coast of Africa.
I've got a pretty good understanding of networks and computers (MCSE) but am very weak on Cisco and complex routing.
My situation is that we've just left the shipyard and all our equipment has been upgraded. I've laid in some fiber to various places and have a 4 vlans setup and all feeding into our satellite modem.
What I want to do is use an old 3550 to setup a network for some IPX applications we have. Yes IPX!! These are dos based applications even! Anyway.. I want to set the 3550 up as an IPX switch basically.
Overkill I know but when your orders take 6 months to a year to be delivered you have to improvise. The 3550 is the only thing I've got left with multiple ports in it.
I've gone in and cleared the config.text and have the router set to factory defaults.
Is there a way to turn the 3550 into a switch capable of passing IPX?
This will be temporary until I can get home and pick up a $30 switch to bring back.
Thanks for any and all help
James
16 years 2 months ago #33241 by broadcaststorm
Replied by broadcaststorm on topic Re: 3550 questions
IPX is a routed protocol, so the switch will ignore it at Layer 2. If you want to route at Layer 3 using the switch, then you need to use a routing protocol that supports IPX. If you have all Cisco kit, then EIGRP has to be the way to go.
To turn a 3550 interface from a switch interface to a routing interface, go to the interface command and simply type no switchport. This turns the interface in to a router interface.
Below is the show run output from a 3560 which has had no switchport configured on int fa 0/1...
Cisco_3560#sho run
Building configuration...
Current configuration : 1102 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Cisco_3560
interface FastEthernet0/1
no switchport
no ip address
duplex auto
speed auto
Now you can add an IP address to the interface, switch on IP routing (at global config) and configure EIGRP.
16 years 2 months ago #33242 by broadcaststorm
And the same switch with IP routing switched on;
Cisco_3560#sho run
Current configuration : 1115 bytes
version 12.2
hostname Cisco_3560
ip routing
no switchport
no ip address
duplex auto
speed auto
Don't forget to do that IF you want to use the switch as a router as well as a switch :wink:
16 years 2 months ago #33243 by broadcaststorm
And finally, the same switch with an IP address configured on int fa 0/1 and EIGRP up and running;
Cisco_3560#sho run
Current configuration : 1197 bytes
version 12.2
hostname Cisco_3560
ip routing
no switchport
ip address 192.168.10.1 255.255.255.0
duplex auto
speed auto
<output truncated>
router eigrp 100
network 192.168.10.0
no auto-summary
ip classless
line con 0
line vty 0 4
login
end
