how ARP Protocol Works
14 years 9 months ago #32798
by amiit
how ARP Protocol Works was created by amiit
dear all...
Plz let me know how ARP Protocol Works.....or Suggest me Link where i can get the full Details of it.......
Thanks & Best Regards
amiit
amiit
14 years 9 months ago #32799
by KiLLaBeE
Replied by KiLLaBeE on topic Re: how ARP Protocol Works
Here's a suggestion:
Install and run Wireshark on your computer for a while. Occasionally, you will see ARP packets come by, and the "Info" section of the packet will say something along the lines of "Who has 192.168.1.x? Tell 192.168.1.100" (assuming that your network is in the 192.168.1.0 network). Shortly after, you should see a response from the computer with that IP address responding with "192.168.1.x is at XX:XX:XX:XX:XX:XX." If the IP address isn't on your network, you'll notice that the ARP packet instead asks for the MAC address of the default gateway, but a response is still received in that format.
That's basically how ARP works -- the sending host asks who owns a specified IP address and the host responds with its MAC address.
If you want more details (there really isn't a whole lot else left), you'll have to tell me what you've discovered so far about the protocol based on your research
Time to create page: 0.115 seconds
