asa privilege level required to connect to vpn
- skepticals
- Elite Member
15 years 7 months ago #31609
by skepticals
asa privilege level required to connect to vpn was created by skepticals
When creating a user account that only needs to connect to the remote access VPN in order to connect to the internal network...
Is there a privilege level they need?
15 years 7 months ago #31632
by ikon
Replied by ikon on topic Re: asa privilege level required to connect to vpn
Nope.
How are you creating users? RADIUS or Local Auth?
As long as you have told the ASA what type of Auth to use for VPN/SSL VPN connections it will either look up Radius or Local.
No privilege required.
- skepticals
- Elite Member
15 years 7 months ago #31643
by skepticals
Replied by skepticals on topic Re: asa privilege level required to connect to vpn
I am doing the authorization to a local user account. I can create a user with a priv. level of 0?
15 years 7 months ago #31664
by r0nni3
Certifications:
CCNA - Have it
CCNA Security - Have it
CCSP - Almost!!!!
Replied by r0nni3 on topic Re: asa privilege level required to connect to vpn
yep since privilege levels are only needed to manage the ASA but not for VPN.
Certifications:
CCNA - Have it
CCSP - Almost!!!!
