Max IP packet size and Max Ethernet frame size
15 years 8 months ago #31118
by Deepti
Max IP packet size and Max Ethernet frame size was created by Deepti
Max Ethernet frame size is 1500bytes while max IP packet size is 536 bytes. So lets say I have 100kb of data, wrapping it in different headers how much data will I be able to send in one pkt ?
When will fragmentation occur?
15 years 6 months ago #32232
by Kajitora
itgamers.blogspot.com
Replied by Kajitora on topic Re: Max IP packet size and Max Ethernet frame size
Theres alot to such a small questions.
The first part is, the max size of a Ethernet frame is configuration. For example, if you have a gig or above Ethernet you can use jumbo frames which can be 9000 bytes. And just enabling dot1q will make your frames 1512 bytes.
That being said the Max size of a IP packet is 65,535, 576 bytes is the minimum size required to be IEEE complaint for a host. Or I guess that could be better said that a host has to be able to accept a IP Packet of at least 576 bytes. Most modern implementations will use much larger packets.
Last piece is there is a MTU configured on a host that tells it how big to make a ip packet. Alot of systems (Macs/Windows/Ubunto i know for sure) use 1500 as the default MTU.
