Port Security on Switch - Sticky MAC-Address Problem
15 years 8 months ago #31106
by gvkalra
Port Security on Switch - Sticky MAC-Address Problem was created by gvkalra
Hey All, Hi
Before writing my question, here's the output from the Switch:
Switch#show running-config
(Showing only relevant Port)
Building configuration...
Current configuration : 1306 bytes
version 12.1
no service pad
service timestamps log uptime
hostname Switch
ip subnet-zero
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
spanning-tree extend system-id
interface FastEthernet0/21
switchport mode access
switchport port-security
switchport port-security mac-address sticky
switchport port-security mac-address sticky 001f.d0e7.9d31
interface Vlan1
no ip address
no ip route-cache
shutdown
ip http server
line con 0
logging synchronous
line vty 0 4
login
line vty 5 15
login
mac-address-table aging-time 10
end
_________________________________
Switch#show port-security interface fastEthernet 0/21
Port Security : Enabled
Port Status : Secure-up
Violation Mode : Shutdown
Aging Time : 0 mins
Aging Type : Absolute
SecureStatic Address Aging : Disabled
Maximum MAC Addresses : 1
Total MAC Addresses : 1
Configured MAC Addresses : 0
Sticky MAC Addresses : 1
Last Source Address : 0000.0000.0000
Security Violation Count : 0
Switch#show mac-address-table dynamic
Mac Address Table
Vlan Mac Address Type Ports
All 000b.5fae.71c0 STATIC CPU
All 0100.0ccc.cccc STATIC CPU
All 0100.0ccc.cccd STATIC CPU
All 0100.0cdd.dddd STATIC CPU
1 0000.0c92.54cf DYNAMIC Fa0/9
1 0010.7b3a.95f8 DYNAMIC Fa0/12
1 001f.d0e7.9d31 STATIC Fa0/21
Total Mac Addresses for this criterion: 7
My Question is this:
Check these out again
(Quote1)switchport port-security mac-address sticky 001f.d0e7.9d31
(Quote2)Last Source Address : 0000.0000.0000
(Quote3)1 001f.d0e7.9d31 STATIC Fa0/21
Why is (Quote2) showing Last Source Address as 0000.0000.0000? I did the same thing on Packet Tracer 5.1 and it is showing the sticky MAC-ADDRESS 001f.d0e7.9d31 in place of 0000.0000.0000 (which it should).
Any problem with the Switch?
version 12.1
no service pad
hostname Switch
ip subnet-zero
interface Vlan1
no ip address
no ip route-cache
shutdown
ip http server
line con 0
logging synchronous
line vty 0 4
login
line vty 5 15
login
end
Aging Time : 0 mins
Mac Address Table
15 years 8 months ago #31110
Replied by S0lo on topic Re: Port Security on Switch - Sticky MAC-Address Problem
hmmm, I tried it and it works with me on both packet tracer and my 2950 switch. You are right it should be working!!, got no idea why it doesn't
Did you by any chance reload the switch before issuing show port-security interface fastEthernet 0/21. The "Last Source Address" would not survive a restart/reload.
15 years 8 months ago #31120
by gvkalra
Replied by gvkalra on topic Re: Port Security on Switch - Sticky MAC-Address Problem
No I didn't reloaded the Switch .... Looks like there gotta be some problem with the Switch IOS....
15 years 8 months ago #31122
Very possible, getting the latest IOS (if it's not already there) might help.
Time to create page: 0.244 seconds
