Ping load on newtwork
15 years 5 months ago #30955 by Alans
Ping load on newtwork was created by Alans
Any one know how Ping affects network load if used as a sensor in monitoring softwares like PRTG or WUG?
Is it safe to put Ping sensor for all devices on the network to ping each x second or min?
always Face your Fears...
15 years 5 months ago #30960 by TheBishop
Replied by TheBishop on topic Re: Ping load on newtwork
It's pretty safe and doesn't generate too much traffic - unless you go for insane levels of monitoring. A basic ICMP ping after all is only 64 bytes for the request and 64 bytes for the reply - a mere 128 bytes all in. I usually go for a trade-off between number of devices and frequency of pings to keep the traffic levels small. And you can always use different frequencies for critical devices (that you want to be alerted on quickly) and others that aren't so important and where five minutes or so will do.
15 years 5 months ago #30965 by Alans
Replied by Alans on topic Re: Ping load on newtwork
I got it, thanks TheBishop :)
Time to create page: 0.116 seconds
