Step by step: deploying wireless in packet tracer
15 years 10 months ago #30563 by pedenski
Hello, Can you guide me how to make a wireless connection in packet tracer, Im really a newbie to WLAN, i wanted to learn. can you guide me pls?
Uhm, what should i configure first? AP or the Linksys?
15 years 10 months ago #30565 by S0lo
Hello pedenski,
The Generic AP in packet tracer works as a simple bridge (2 ports switch). One port is wired and the other is wireless. As far as I know, it does not have routing capabilities. On the other hand, the linksys wireless router is a fully equipped device similar to the ones you see in your home's ADSL modem/router that connects you to the internet.
Here is a simple example network file using the AP: www.2shared.com/file/6190181/30686b60/APex.html
15 years 10 months ago #30569 by pedenski
wow. so much thank you. I had a hard time figuring that out..
edit:
hi, i had made some design and i cant ping laptop pc10 to desktop pc1.. seperated only by a router...
should i use RIP to each interface?
www.2shared.com/file/6206265/52f73ad/ap_online.html
15 years 10 months ago #30579 by S0lo
I don't see any problem with the network you posted. But it seams the problem is in the PDU list. I recreated it and it works now. I can ping PC0 and PC1 from PC10. No problems at all. Try waiting a while until PC0 and PC1 get their IPs via DHCP. Fixed file here: www.2shared.com/file/6214146/3b3f1ff7/ap_fixed.html
No you don't need RIP in this case neither the static route line:
ip route 192.168.2.0 255.255.255.0 FastEthernet0/1
Because both networks are directly connected to the router, So route entries for both networks will automatically be inserted into the routing table of the router. By the way, you can ping using the PC's command prompt instead of the PDU list.
15 years 10 months ago #30583 by pedenski
Thank you Thank you :D
Got it all working...^^
