OSI model
15 years 10 months ago #30461 by diamondfeather
OSI model was created by diamondfeather
I have studies OSI model for long, however, one thing always comes in my mind that why whoever talk about OSI model, they treat Application layer as layer 7 and Physical layer as layer 1 ?
I think we should consider the layers in proper order i.e.
Application .... layer 1
Presentation .... layer 2
Session .... layer 3
Transport .... layer 4
N/w .... layer 5
Data Link .... layer 6
Physical .... layer 7
:arrow: I know it does not seem a big thing but i think it is important to discuss it. What do you think guys ?
15 years 10 months ago #30462 by timparker
Replied by timparker on topic Re: OSI model
I would be interested in hearing your reason for the switch. I haven't seen it listed this way, as you won't have any applications if you don't have a Physical layer. You have to build from the ground up before things will work.
15 years 10 months ago #30464 by sose
Replied by sose on topic Re: OSI model
I have read a lot of text about OSI model and many authors agree that the positioning can be either ways, depending on whether you are a reciever or sender. when you are a reciever then the default applies but when you are a sender then your case applies. it is just for exam purpose that we need to adopt a particular approacch to avoid confusion.
sose
15 years 10 months ago #30471 by diamondfeather
Replied by diamondfeather on topic Re: OSI model
@timparker ..
I have just discussed the numbering of different layers while keeping every layers at their own place without effecting them.
For the switch as u mentioned, it will be like this,
Switch works in layer 7 (physical layer) and layer 6 (data link layer) of the OSI model instead of its working in layer 1 (physical layer) and layer 2 (data link layer).
I just want the numbering to be in ascending order nothing else.
@sose ..
Thankyou for mentioning the exact facts which i was looking for.
15 years 10 months ago #30473 by timparker
My point is that no matter whether you are the sender or receiver. You send nothing anywhere, if you don't have a network.
If we refer to physical as Layer 7 as you mention, we don't "normally" start counting at 7. Just seems foreign to me and strange. Guess I haven't been reading enough. My thought process is you start at the bottom and work your way up to build what you need (whether that be a network, a house or a skyscraper -- you wouldn't build the roof first on a house.
Interesting thoughts though.
15 years 9 months ago #30689 by marora80
Replied by marora80 on topic Re: OSI model
as u said that you have studied a lot about the OSI Model. then please do think bit logically you will get ur answer at own. basically it is the physical layer which sends the bits from the sender to the destination and the layer in networking model which is basically responsible for this task should be named as the first layer. on to contrary of ur question as the layer which brings out the packet or
data in to send through the network should be considered at the last layer and that is why the application layer is named as the seventh layer of the network model. more to this this packed is to be further divided into frames and then submitted to the physical layer for sending and that is also the one of the reason for naming the physical layer the first layer...
