Few n/w questions
17 years 6 months ago #29780 by netsamurai
Few n/w questions was created by netsamurai
1.DHCP ack is ?
a)unicast
b)Multicast
2.)DHCP works in which layer of OSI?
3.)Error correction done in which layer?
Please answer(with explantion) it and help me
17 years 6 months ago #29783 by sose
Replied by sose on topic Re: Few n/w questions
a) unicast
dhcp works at application layer - layer 7
error correction is at layer 4 transport layer, but error detection is at layer 3 network layer
The client broadcasts a DHCPDISCOVER message on its local physical
subnet. The DHCPDISCOVER message MAY include options that suggest
values for the network address and lease duration. BOOTP relay
agents may pass the message on to DHCP servers not on the same
physical subnet.
Each server may respond with a DHCPOFFER message that includes an
available network address in the 'yiaddr' field (and other
configuration parameters in DHCP options). Servers need not
reserve the offered network address, although the protocol will
work more efficiently if the server avoids allocating the offered
network address to another client. When allocating a new address,
servers SHOULD check that the offered network address is not
Message Use
DHCPDISCOVER - Client broadcast to locate available servers.
DHCPOFFER - Server to client in response to DHCPDISCOVER with
offer of configuration parameters.
DHCPREQUEST - Client message to servers either (a) requesting
offered parameters from one server and implicitly
declining offers from all others, (b) confirming
correctness of previously allocated address after,
e.g., system reboot, or (c) extending the lease on a
particular network address.
DHCPACK - Server to client with configuration parameters,
including committed network address.
DHCPNAK - Server to client indicating client's notion of network
address is incorrect (e.g., client has moved to new
subnet) or client's lease as expired
DHCPDECLINE - Client to server indicating network address is already
in use.
DHCPRELEASE - Client to server relinquishing network address and
cancelling remaining lease.
DHCPINFORM - Client to server, asking only for local configuration
parameters; client already has externally configured
network address.
www.ietf.org/rfc/rfc2131.txt
17 years 6 months ago #29795 by netsamurai
Replied by netsamurai on topic Re: Few n/w questions
Thx SOSE
17 years 5 months ago #29961 by cscrtr
Replied by cscrtr on topic Re: Few n/w questions
a) unicast
physical subnet.
Message Use
in use.
network address.
Just want to inform that Error detection occurs at Layer 2.
Because Layer 2 ( Data Link layer ) adds footer and tailer.. In the tailer it adds FCS ( frame check sequence - 4 bytes ) which checks whether frame is error free or not.
Thanks..
17 years 5 months ago #29974 by sose
woops !! error detection is done at layer 2 datalink
