Frame Relay configuration in Packet Tracer
17 years 6 months ago #29657
by SteveP
Frame Relay configuration in Packet Tracer was created by SteveP
I'm thoroughly confused about configuration of Frame Relay. We don't have access to a cloud simulator so have to rely on Packet Tracer. I have two routers connected via a serial cable. The relevant parts of <show run> are:
FIRST ROUTER
interface Serial2/0
bandwidth 56
ip address 10.20.30.1 255.255.255.0
encapsulation frame-relay ietf
frame-relay map ip 10.20.30.2 203 broadcast
frame-relay lmi-type ansi
no keepalive
clock rate 56000
SECOND ROUTER
interface Serial2/0
bandwidth 56
ip address 10.20.30.2 255.255.255.0
frame-relay map ip 10.20.30.1 201 broadcast
no keepalive
The DCE end is attached to the first router.
I can't ping one serial interface from the other. I haven't configured anything else. It appears that the maps have been configured:
show frame-relay map
Serial2/0 (up): ip 10.20.30.2 dlci 203, static, broadcast, IETF, status defined, active
Serial2/0 (up): ip 10.20.30.1 dlci 201, static, broadcast, IETF, status defined, active
Does anyone have any idea why this isn't working? Are my configurations correct? Could there be a bug in Packet Tracer?
Thanks for your time.
FIRST ROUTER
interface Serial2/0
bandwidth 56
no keepalive
clock rate 56000
SECOND ROUTER
interface Serial2/0
bandwidth 56
no keepalive
- broadcaststorm
- Junior Member
17 years 4 months ago #30277
by broadcaststorm
Replied by broadcaststorm on topic Re: Frame Relay configuration in Packet Tracer
In packet Tracer 5 and 5.1, click on the WAN Emulation Cloud, select one of the two clouds that appear and place it in the work area. Open the "picture" and click the Config tab. There will be a Frame-Relay option on the left side. It's a bit of a fiddle to get working, but it does work well enough.
17 years 4 months ago #30283
by SteveP
Replied by SteveP on topic Re: Frame Relay configuration in Packet Tracer
Thanks for the tip. Since posting the initial question, I've looked at this and managed to get it working - both via a FR cloud as well as 2 routers back to back.
