Issue with Cisco L3 switch with multiple DHCP scopes.
- skepticals
- Elite Member
16 years 2 months ago #29313
by skepticals
Issue with Cisco L3 switch with multiple DHCP scopes. was created by skepticals
VLAN 1
DHCP Scope 10.15.2.0
VLAN 8
DHCP Scope 10.15.8.0
All the ports on the switch are in VLAN1, but I am getting some PCs getting an IP from VLAN 8. How is this possible?
I did notice that the VLAN interface does not have an IP assigned to it, would this cause an issue?
I thought that a PC would have to be in the same VLAN because DHCP is based on broadcasts.
What could cause this?
VLAN 8
16 years 1 month ago #29347
by Smurf
Replied by Smurf on topic Re: Issue with Cisco L3 switch with multiple DHCP scopes.
No one has problably replied because what you are describing shouldn't be happening. You are correct, if the switch port is in a particular VLAN then it will be sgemented at layer 2 from all other VLAN ports.
Hmm, can you do a packet capture ?
I would also double check the VLAN configuration.
16 years 1 month ago #29357
Replied by S0lo on topic Re: Issue with Cisco L3 switch with multiple DHCP scopes.
I'd first double check the VLAN config as Smurf suggested.
What DHCP server(s) are you using? is it a router or a Win/linux box?. If the later, then make sure the DHCP server for VLAN8 is connected to a VLAN8 port on the switch. If your using a router as your DHCP server (i.e router on a stick for both VLANs), then I'd double check the masks set for the two scopes/pools (apparently /24 in your case).
Still no hope? Then what happens when you set one of those ports to VLAN8, does the PC connected get a VLAN8 IP or a VLAN1 IP?
- skepticals
- Elite Member
16 years 1 month ago #29367
by skepticals
Replied by skepticals on topic Re: Issue with Cisco L3 switch with multiple DHCP scopes.
Sorry, I didn't make myself clear. The DHCP is given from the Cisco switch itself.
16 years 1 month ago #29373
Never mind, A post of your config could help.
