Monitoring LAN
  • gagamboy
  • Topic Author
  • Visitor
  • Visitor
16 years 2 months ago #29303 by gagamboy
Monitoring LAN was created by gagamboy
Hi Guys,
Do you have any ideas how to monitor your LAN? Like for existing virus that exist in PC and infects other PC via network?
Appreciate your feedback. Thanks in advance.
Cheers! :D
16 years 2 months ago #29305 by TheBishop
Replied by TheBishop on topic Re: Monitoring LAN
Sounds like you're talking about network-based IDS. This is a system which monitors the traffic flowing on your network and will raise an alarm if it detects packets with particular byte-sequence signatures in them. IDS options range from free public domain to comercial megabucks offerings. I suggest you start at the free end and install something like Snort so you can condict an evaluation
  • gagamboy
  • Topic Author
  • Visitor
  • Visitor
16 years 2 months ago #29309 by gagamboy
Replied by gagamboy on topic Re: Monitoring LAN
Thanks TheBishop, I'll take note of that. Does it have any impact on my network like bandwidth usage?
Guys any more ideas to share? I believe all of us need this kind of tools.
Thanks in advance again.
16 years 2 months ago #29310 by TheBishop
No. Typically you'd create a port mirror on your central switch stack to replicate (say) all the traffic on your connection to the outside world/server farm/main VLAN/DMZ/whatever you want. The destination of this would be the box your IDS runs on. So you're not creating any additional traffic to do this
16 years 2 months ago #29312 by skepticals
Replied by skepticals on topic Re: Monitoring LAN
Which free IDS systems do you suggest?
