dhcp
21 years 4 weeks ago #2878
by sahirh
Ten firewall.cx points to greenice for answering a question I was not sure how to answer.
21 years 4 weeks ago #2882
by UHSsncmrm
A secondary address is also good for when you bring another node up on your WAN. Say for instance you acquire another site, as businesses are want to do, this new site doesn't have the same addressing scheme that your others do. Rather than change all devices at new site to your addressing scheme, you can add your network as a secondary address and voila, you can now route their traffic over your network with minimum configuration and headache to their technical folk, thereby making the transition to your company smoother. IE no NATing, DNS changes, default gateway changes, minimal host file tweaking, all resulting in lower downtime and happier end-users.
You can always go back after the waters settle and coerce them into a complete re-addressing plan after you've built relationships.
This rarely ever happens. Who has that kinda time?
21 years 4 weeks ago #2893
by sahirh
Ok ok.. ten points to you as well
One day I'll tell my grandchildren,
"I was a moderator.. and they called me the most benevolent moderator in the 63.247.0.0/16 address range"
21 years 2 weeks ago #2992
by indebluez
hi guys, thax alot for the replies,, really appreciate it...
i have cable access for my internet..and i tried to
disable the connection and enabled it later....shouldnt the ip address change?
coz when i click on the connections, status and then the tab support...i get the same ip addressand default gateway...
i thought to conserve the number of ip addresses...each time i disconnect n connect i should get a different ip add for my host....
help:)
help:)
21 years 2 weeks ago #2993
by Neon
The main reason why you probably get the same IP address is that the ISP has most likely given you a static number... however there are cases I have seen where there are dynamic allocations of numbers (i.e. dialup) where after a few redials to the ISP after being dc that I have been given the same IP address. I would assume that it would have to be something with address leases not expiring...
But as far as your question goes I think you must buy the IP address when you get your cable account. I suppose also it’s easier for them to manage their users, saying this user has this IP address so they know who to blame when they do naughty things rather than checking their logs for who had what/when *points finger @ lazy ISPs*
21 years 2 weeks ago #2997
by mew
The static IP address is a good guess but you should be aware of the fact that:
DHCP – depending on the source has a default given lease period. With Cisco routers it is 24 hours. With other servers it can easily be as long as seven days. If you release your IP and immediately take another the odds are it will be the same IP.
