Classless and Classful, RIPv1 and RIPv2
16 years 4 months ago #28437
by nezzy999
Classless and Classful, RIPv1 and RIPv2 was created by nezzy999
From what I know RIPv1 is a classful protocol and RIPv2 is a classless protocol.
I have become confused though as I was using RIPv1 on my 2811 router and when I input the command, show running-config it states;
<**Lots of info**>
ip classless
<**Lots of info**>
I noticed this line "ip classless", now why would this line be included in the readout? when I am using Ripv1?
I asked my tutor at uni and he was also unsure, does anyone have any ideas or theories?
<**Lots of info**>
ip classless
<**Lots of info**>
16 years 4 months ago #28438
by nezzy999
Replied by nezzy999 on topic Re: Classless and Classful, RIPv1 and RIPv2
After a discussion with some of my peers we have come up with the theory, that
RIPv1 is also classless as when it recieves a rip update of
172.16.0.0 on an interface which has a mask of /8 it will not apply the classful mask of /16, it will apply the /8 mask of the interface it recieved the update on?
16 years 4 months ago #28439
Replied by S0lo on topic Re: Classless and Classful, RIPv1 and RIPv2
It can be quite confusing at the beginning. But it eventually sinks in. ip classless has a totally different job than what RIP or RIPv2 does.
ip classless affects the way routes are searched for when a packet arrives at a router. If ip classless is not configured (using the no ip classless command) then a packet will NOT be routed using a route that has a subnet mask less than the classfull mask of the packet's destination IP. For example, a packet with a destination IP address 194.1.1.1 (Class C, /24). Will be routed by a route like 194.1.1.0/28 and will be routed by a route like 194.1.1.0/24 BUT it will not be routed by a route like 194.1.0.0/22 or by 194.0.0.0/16. Since /22 and /16 are less than the classfull mask /24 (i.e super nets).
If ip classless is configured, this restriction is released. a packet can be routed by any route regardless of the subnet mask. This is why default routes (that has a mask of /0) will never work unless you have ip classless configured. More here: www.cisco.com/en/US/tech/tk365/technolog...4823.shtml#classless
RIP and RIPv2 has no relation to this. RIP does not send subnet-masks during updates. It always assumes classful masks. RIPv2 sends subnet-masks. Thats why RIP is said to be classfull and RIPv2 is classless.
Thats as far as I know, any one, please correct me if I'm wrong.
- server1703
16 years 4 months ago #28446
by server1703
Replied by server1703 on topic Re: Classless and Classful, RIPv1 and RIPv2
Exactly like that Solo. You are correct.
16 years 4 months ago #28447
by Chojin
Replied by Chojin on topic Re: Classless and Classful, RIPv1 and RIPv2
I think they should fire your tutor, that he is not sure about RipV1
Rip v1 uses Broadcast and doesn't send a subnet mask in its advertisements.
Rip v2 uses Multicast and DOES send a subnet thus makes it suitable for classless updates
- fagulhaspt
16 years 5 days ago #30059
by fagulhaspt
Replied by fagulhaspt on topic Re: Classless and Classful, RIPv1 and RIPv2
For more info about the "ip classless" influence in the routing process of Cisco Routers, have a look at here:
www.cisco.com/en/US/tech/tk365/technolog...823.shtml#forwarding
It says that:
- It doesn't interfere with the way the routing table is built - the routing table is filled in the same way with or without this command: routing protocols supply routes with administrative distances/metrics, and the routing table chooses among them the routes with the best administrative distance/metric, to be used in the routing table
- It *does* interfere in the way the routing table is "read" to decide where to forward a packet, as explained by SOlo.
It says that:
