nic work at which layer.
16 years 6 months ago #27894 by abi1929
nic works at which layer... is it right to say it work at 1 as well as 2 ..
16 years 6 months ago #27896 by SteveP
Replied by SteveP on topic Re: nic work at which layer.
That is as I understand it.
16 years 6 months ago #27900 by Chris
Replied by Chris on topic Re: nic work at which layer.
Network cards are said to work on layer 2 (Datalink - Mac Address), but you can also argue that they also work on layer 1 (Physical) as they contain the jack where the network cable and electrical signals terminate (or are generated when transmitting).
16 years 5 months ago #27924 by seanjuan
A NIC card is a Layer 1 and a Layer 2 device.
The NIC card is a Layer 1 device because it sends data over physical media such as a CAT5 cable.
The NIC card is a Layer 2 device because there are two sub layers on Layer 2. The Logical Link Control (LLC) and Media Access Control (MAC). The MAC sub layer communicates with hardware such as NIC cards by using their MAC addresses
