Multicast Routing Protocols
16 years 6 months ago #27852
by pranava
Multicast Routing Protocols was created by pranava
What is the difference between PIM-SM and DVMRP and why both are required/used ? Please help me regarding this???
15 years 10 months ago #30956
by Deepti
Replied by Deepti on topic Re: Multicast Routing Protocols
1. PIM-SM is a Multicasting Routing protocol that is independent of the Unicast Routing Protocol. This means that PIM doesnt create its own Unicast Routing table for Reverse Path Checking that the other Multicast Routing Protocols do. Hence its called "Protocol Independent"
PIM-SM is also called Sparse Mode protocol as it depends on explicit join messages from the listeners to construct its multicast routing tree. This means that PIM-SM will flood the network with multicast traffic only if the network has one/more interested receivers on it.
2.DVMRP also uses the sparse mode but it creates its own unicast routing table for reverse path forwarding.
Time to create page: 0.078 seconds
