OSPF question - your help needed please
17 years 10 months ago #27820
by Damien610
OSPF question - your help needed please was created by Damien610
I have 3 routers - London, Ottawa and Brasilla connected via a switch configured on OSPF with Loopback addresses
The show ip ospf neighbour command on each router displays the below….
London (loopback 192.168.31.11)
Neighbor ID Pri State Dead Time Address Interface
192.168.31.22 1 FULL/BDR 00:00:32 192.168.1.2 Ethernet0
192.168.31.33 1 FULL/DR 00:00:35 192.168.1.3 Ethernet0
Ottawa (loopback 192.168.31.22)
192.168.31.11 1 FULL/DROTHER 00:00:31 192.168.1.1 Ethernet0
192.168.31.33 1 FULL/DR 00:00:33 192.168.1.3 Ethernet0
Brasilla (loopback 192.168.31.33)
192.168.31.11 1 FULL/DROTHER 00:00:33 192.168.1.1 Ethernet0
192.168.31.22 1 FULL/BDR 00:00:33 192.168.1.2 Ethernet0
My question is why is the DROTHER router displaying FULL as the state
I though only DR and BDR were meant to be full state, shoudnt the DROTHER state be 2-way
The below is taken from a OSPF guide ….
‘On a multi-access network, OSPF routers will only form Full adjacencies
with DRs and BDRs. Non-DRs and non-BDRs will still form adjacencies,
but will remain in a 2-Way State. This is normal OSPF behavior.’
:I though only DR and BDR were meant to be full state, shoudnt the DROTHER state be 2-way
:The below is taken from a OSPF guide ….
17 years 10 months ago #27828
by novembre
Replied by novembre on topic Re: OSPF question - your help needed please
The FULL/DROTHER you see in your examples is the full adjacency from the DR / BDR perspective. You will have a 2-WAY state between routers which are neither DR or BDR.
Maybe an example will help, lets introduce another router into your lab (or slightly modify mine)
Auckland (loopback 192.168.31.44) Elections are rigged such that .33 = DR and .22 BDR
The view from London (192.168.31.11):
192.168.31.22 100 FULL/BDR 00:00:39 192.168.1.200 FastEthernet0/0
192.168.31.33 200 FULL/DR 00:00:38 192.168.1.100 FastEthernet0/0
192.168.31.44 0 2WAY/DROTHER 00:00:38 192.168.1.102 FastEthernet0/0
The view from Auckland (192.168.31.44):
192.168.31.11 0 2WAY/DROTHER 00:00:30 192.168.1.101 FastEthernet0/0
192.168.31.22 100 FULL/BDR 00:00:34 192.168.1.200 FastEthernet0/0
192.168.31.33 200 FULL/DR 00:00:39 192.168.1.100 FastEthernet0/0
17 years 10 months ago #27833
by SteveP
Replied by SteveP on topic Re: OSPF question - your help needed please
@Damien610 - do you have the link to the OSPF guide that you referenced? I really liked (and, for once, completely understood!) OSPF and found it fascinating (not at all like EIGRP!).
17 years 10 months ago #27834
by Damien610
Replied by Damien610 on topic Re: OSPF question - your help needed please
I see :idea: ........thanks novembre for the well worded explaination,
Regards
Damien
Regards
Damien
17 years 10 months ago #27835
by Damien610
Sure, go to www.routeralley.com/ra/guides.html and select Open Shortest Path First (OSPF) guide
17 years 10 months ago #27836
by SteveP
Hey, that's a pretty cool site. I'll be printing several of the guides off next time that I'm at college - even those which deal with topics that we've covered previously! From my quick skim of the material, it seems that he's got an easily understood method of teaching some complex material.
I can't recall if there's a sticky here for useful sites. If so, routeralley should be in there.
