Layer 3 switching vs Routing
16 years 2 months ago #27844
by ZiPPy
ZiPPy
Replied by ZiPPy on topic Re: Layer 3 switching vs Routing
I'd be curious to know when to use a router for a VLAN and when to use a L3 switch. If the fact stands with Patiots post on the speeds, we can pretty much assume you choose the devices based on the performance and bandwidth your looking to pass.
We can't only look at the network view, but also the cost for a real network environment. A Catalyst 3560 which is a L3 switch costs almost double that of a Catalyst 2960 switch which is L2. Now for that large cost between the two, you could purchase a 1700 series router and create a standard VLAN.
There must be a valid reason why you choose one topology setup over the other. I guess a VLAN isn't just a VLAN. :roll:
Curiosity hits!!!
ZiPPy
Curiosity hits!!!
ZiPPy
ZiPPy
16 years 2 months ago #27845
by Patiot
Replied by Patiot on topic Re: Layer 3 switching vs Routing
Yes the costs are high for the equipment but the perport cost is lower .
Patiot
Patiot
- gagamboy
- Visitor
16 years 1 month ago #27877
by gagamboy
Replied by gagamboy on topic Re: Layer 3 switching vs Routing
www.cisco.com/en/US/docs/switches/lan/ca...routing.html#wp13354
www.cisco.com/en/US/tech/tk389/tk815/tec...186a008019e74e.shtml
>>> Nice one you got there Solo. Hopefully I can deeply understand it and be able to join you someday in this kind of discussion.
regards,
Gagamboy
regards,
Gagamboy
Time to create page: 0.117 seconds
