Course Outline in Networking
- gagamboy
- Visitor
16 years 5 months ago #27788
by gagamboy
Course Outline in Networking was created by gagamboy
Hi Guys,
Since I am new in Networking, can you please help me or guide me on this.
Can you please give me an outline on what I need to study or focus first.
I have a knowledge on basic networking, basic knowledge on OSI layer to be exact.
thanks and more power!
regards,
Gagamboy
regards,
Gagamboy
16 years 5 months ago #27806
by Azilla
Replied by Azilla on topic New to Networking
since you are new I would say keep getting a better picture of the Osi model understand every layer in and out and what protocols are supported at each layer. Then get some equiptment to start your own home network cheap cisco router ect. Experience is key start in the industry too working for a cable company or telco helps . Also start thinking about the ccna asap and then start learning the backbone of ISp's like ,Wavelength divison multiplexing,Sonet rings ,Atm also protocols like Mpls Bgp and Snmp hope this helps...
16 years 5 months ago #27808
Replied by S0lo on topic Re: Course Outline in Networking
Also, you could try the guides here. Click the "Networking" menu (first menu on the left). There is much more to read than what meets the eye.
- gagamboy
- Visitor
16 years 5 months ago #27878
by gagamboy
Replied by gagamboy on topic Re: Course Outline in Networking
Hi Solo,
Yes, you are right! This forum helps a lot, especially to a newbie like me. Thanks for the support guys.
regards,
Gagamboy
regards,
Gagamboy
16 years 5 months ago #27913
No prob. gagamboy
Also, if your thinking of CCNA in the near feature, I'd recommend getting your hands into the "Cisco Academy" material. Honestly, it's one of the best I've seen yet. Very clear, with flash illustrations and detailed to the bit level. I'd also recommend trying "Packet Tracer", it's a good help if your short of cisco equipment.
- gagamboy
- Visitor
16 years 5 months ago #27914
by gagamboy
Hi Solo,
Thanks for the info. Yes, I am also looking to take a CCNA someday and I already started to study the cisco OSI layer and basic net configs in switches. I am now using Boson simulator and I will also try the packet tracer. Thanks a lot.
Cheers!
Gagamboy
Cheers!
Gagamboy
