Remote Desktop Connection on wireless Network
16 years 7 months ago #27207
by chitti
Remote Desktop Connection on wireless Network was created by chitti
Hey Everyone,
I have a small doubt, Is it possible to establish a Remote Desktop Connection on wireless Network ??? If yes then does it work from Windows Vista to Windos XP or either ways ???
Raj
Raj
16 years 7 months ago #27208
Replied by S0lo on topic Re: Remote Desktop Connection on wireless Network
Sure it's possible on wireless, I tried it. But did not try it on vista though (or vista with XP). But I'm almost certain that it should work, if not by default, you might need to tweak your firewall and remote users settings for it.
16 years 7 months ago #27209
by KiLLaBeE
Replied by KiLLaBeE on topic Re: Remote Desktop Connection on wireless Network
You can remote out from Vista Home Basic but can't remote in. Same with Vista Home Premium. There is a hack that will modify the registry and replace some DLLs in Vista Home Premium to allow you to remote desktop in, though.
16 years 7 months ago #27218
by chitti
Replied by chitti on topic Re: Remote Desktop Connection on wireless Network
Hey KiLLaBeE could you plz let me know what the hack is or how it works ???
16 years 7 months ago #27232
by KiLLaBeE
www.unet.fi/fransblog/2007/08/30/enable-...-vista-home-premium/
Being that I don't have Vista Premium (but rather Home Basic), I haven't had the opportunity to try this myself. I did see a version of this work on XP Pro to allow multiple remote desktop sessions.
16 years 7 months ago #27245
by mapena
Regards,
Miguel
Hi there,
I am running Vista Ultimate( no SP1), and RDC(mstsc) is working fine from Vista to XP and from XP to Vista.
In vista you need to enable: My Pc - System Properties - Remote Tab - Allow connections from computers.....
You have to enable Remote Desktop in your firewall.
Regards,
Miguel
Time to create page: 0.256 seconds
