Limiting network speeds on Cisco devices
18 years 4 months ago #26108 by toddwoo
I'm having trouble getting an interface on a cisco device to rate limit.
I'm trying to cut down the speed of an interface that ties one area into our service provider.
I'm not even 100% sure there is a way to do this on a layer 2 switch.
Anyone got any thoughts?
18 years 4 months ago #26118 by skepticals
I don't think you can rate limit on a layer 2 switch. I know you can do it on layer 2 device.
How are you trying to do it?
18 years 4 months ago #26136 by S0lo
Check the "speed" and "duplex" commands. For example:
switch(config-if)# speed ?
10 Force 10 Mbps operation
100 Force 100 Mbps operation
auto Enable AUTO speed configuration
switch(config-if)# speed 10
18 years 4 months ago #26138 by toddwoo
Ack... Should have included what i'm trying.
I need to rate limit more granularly than 10 or 100 so using the line speed is out.
I'm using a policy on the interface.
config:
policy-map 5mblimit
class layer2
police 5240000 163750 163750 conform-action transmit exceed-action drop
f0/1
service-policy input 5mblimit
no shut
I have a bunch of different policy-maps made 5, 10, 25, 50. But i'm not seeing the speed limited the way I would believe it should be.
Is this the right approach? Should I try something different?
18 years 4 months ago #26143 by skepticals
Humm... I have never tried to rate-limit on a Layer 2 device.
How are you marking your traffic? What is the config for class layer2?
18 years 4 months ago #26146 by toddwoo
mac access-list extended layer2
permit any any
and
class-map match-all layer2
match access group name layer2
I'm pretty sketchy about all of this, which makes it pretty easy for me to screw things up...
