Blocking TCP port 69 also blocks TFTP
16 years 11 months ago #26018
by elp
Blocking TCP port 69 also blocks TFTP was created by elp
Hello guys,
I have a basic question, although a little tricky for me to understand. I was configuring some ACLs on a router, here is the thing I was trying to block TFTP traffic but by mistake I block TCP 69 port instead of UDP 69, both configuration successfully blocks TFTP. But here is the question, how come that blocking TCP:69 also blocks TFTP as TFTP works on UDP:69?
Thanks in advance. : ).
16 years 11 months ago #26025
by ikon
Replied by ikon on topic Re: Blocking TCP port 69 also blocks TFTP
TFTP Uses Some features of the TCP Stack such as acknowledgments, so by blocking tcp on port 69 you are effectivly stopping tftp from be able to establish a proper session with the host.
There are a few applications that use both TCP and UDP like BOOTP, DNS, NFS, SNMP.
Although it is not specifically stated in the RFC for TFTP is is however the case.
