quick help needed
16 years 11 months ago #25931 by m2r007
quick help needed was created by m2r007
I have test beds in the 172.16.110.xxx series and my server has a ip of 10.13.221.xxx.. what and which are the best ways to have connection between them????
16 years 11 months ago #25940 by sp1k3tou
Replied by sp1k3tou on topic Re: quick help needed
You need a layer 3 device doing inter vlan routing.
16 years 11 months ago #25944 by Chris
Replied by Chris on topic Re: quick help needed
As m2r007 noted, you will require a layer 3 switch that will perform the routing between the two networks.
The same result can be archived with a server or router that will need to exist in both logical networks simultaneously so it can perform the routing.
I'd also suggest you take a quick look at our article covering subnet communications and routing to help give you a more graphical view of the above suggestions:
www.firewall.cx/ip-subnetting-routing.php
16 years 11 months ago #25954 by m2r007
Replied by m2r007 on topic thanks 4 the reply guys
pcs in ip addr range 10.13.217.xxx can access the test beds but not 10.13.221.xxx ...........r they in diff subnet?? or Access list blocking???
16 years 11 months ago #26121 by skepticals
Replied by skepticals on topic Re: quick help needed
Depends, what are the subnet masks in use?
16 years 11 months ago #26127 by S0lo
Replied by S0lo on topic Re: quick help needed
It would help of you could give us more details about your network. What router(s), subnet-masks used, how they are connected.
