Supernet routing
17 years 5 days ago #25730 by NeoTech
Supernet routing was created by NeoTech
Hey guys, im unsure if im posting in the right place here, but i need a bit of clarification on supernetting. I cant seem to find anything related to it on the alternative menu.
now i know, using the 'ip classless' command in CISCO IOS software, global config mode, its possible to define a route to cover a range of subnets (a supernet route)
Would i be right in saying a valid supernet route for 192.168.64.0 /20 and 192.168.32.0 /20 would be 192.168.0.0 /16 :?: :?
I thought i'd nailed subnetting but im unsure of this.
regards to all and thanks in advance! :)
Neo
Tech
17 years 4 days ago #25731 by Elohim
Replied by Elohim on topic Re: Supernet routing
Well... if you don't care about what else is there in that space then that will work...
192.168.32.0/20 includes all everything from 192.168.32.0 to 192.168.47.255
192.168.64.0/20 includes everything from 192.168.64.0 to 192.168.79.255
These two /20 subnetwork doesn't really summarize well because they are not continguous. You still have another /20 between the two /20 you mention. However, if you don't care what is really there... and you just want to summarize it with one statement, 192.168.0.0/17 will summarize everything from 192.168.0.0 to 192.168.127.255 which includes the IPs you want.
17 years 4 days ago #25734 by NeoTech
Replied by NeoTech on topic Re: Supernet routing
ok cheers for that. seems like ive finally got subnetting theory down but could you elaborate for me as to what you were trying to explain? did i step on some reserved addresses or something?
Thanks!
Neo
Tech
17 years 4 days ago #25740 by Chojin
Replied by Chojin on topic Re: Supernet routing
What he says,
Is you are summarizing the subnets towards 1 big subnet, but this 1 big subnet also includes ip's not in your range.
this would almost be as summarizing :
10.1.0.0 /16 and 10.2.0.0/16 towards 10.0.0.0/8 (also including the 3-254 subnets).
You don't have a 10.3.0.0/16 in above example.. but this is also included in the summarized subnet. If that doesn't matter, than your good to go :)
17 years 1 day ago #25780 by NeoTech
Hi again chojin :), Thanks for clearing that up.
The example wasn't for anything practical it was just so i was clear i had understood supernet routing.
If im correct, using your example; supernet routing to 10.0.0.0/8 would be usable for networks 10.2.0.0/16 and 10.1.0.0/16 provided there were no other networks in the autonomous system on the 10.0.0.0/8 network... correct?
i can see how much a waste that would be though lol, so many subnets would get flooded. :shock:
Cheers!
Neo
Tech
17 years 1 day ago #25781 by NeoTech
quick note: at time of giving that example my only intention was to cover the whole network 192.168.0.0
i realise it would cause too much traffic to be practical, but in theory wouldn't every node with 192.168.*.* designated to its ip address receive the packet?
Neo
Tech
