I thought I had ip classless nailed - but maybe not
17 years 1 month ago #25478
by SteveP
I thought I had ip classless nailed - but maybe not was created by SteveP
I set up 2 routers, A & B, connected by a WAN (192.168.2.0/24). The LAN attached to A is 192.168.1.0/24 and that attached to B is 172.16.16.0/24. I used RIPv1 and configured the following on B:
router rip
network 192.168.2.0
network 172.16.0.0
In the IOS, ip classless is the default and everything worked in terms of ping between hosts attached to the LANs attached to A & B.
I made the following changes on router B:
no ip classless
router rip
no network 172.16.0.0
network 172.16.16.0
I cleared both route tables and tried the ping between the hosts. I expected it to fail in both directions but it didn't
I looked at both route tables and the networks were there, whether I had configured <ip classless> or <no ip classless>. I was confident that it would fail but obviously my understanding is flawed. Can anyone offer any advice? I'd like a configuration that works with <ip classless> but fails with <no ip classless> because that's the way that I'll learn what's happening. I can't post the running-config files for a couple of weeks because we've finished college until after Easter.
NB, this isn't a question set by our tutor, it's something that I'm doing "under my own steam"!
Thanks for your time.
router rip
network 192.168.2.0
network 172.16.0.0
no ip classless
router rip
network 172.16.16.0
17 years 1 month ago #25480
by sp1k3tou
Replied by sp1k3tou on topic Re: I thought I had ip classless nailed - but maybe not
RIP V1 does not support VLSM. When RIP V1 sees 172.16.16.0/24 it only looks at the first octet and thinks it's a /16 mask. If you turn V2 on it should work if everything else is configured correct since V2 includes subnet mask in the updates.
17 years 4 weeks ago #25482
by SteveP
Replied by SteveP on topic Re: I thought I had ip classless nailed - but maybe not
Perfect - many thanks.
So, just to clarify, if I change from RIPv1 to RIPv2 and use the second configuration above (network 172.16.16.0 rather than network 172.16.0.0), it will work with <ip classless> but fail with <no ip classless>?
Pity I'll have to wait until after Easter to see this in action!
