How to configure Cisco IOS DHCP for per VLAN basis?
17 years 7 months ago #23201
by Jowee
How to configure Cisco IOS DHCP for per VLAN basis? was created by Jowee
I am using a Cisco Router 2600 to act as a DHCP server. It is possible to assign dhcp pool on per VLAN basis? May I know the configuration as well?
Many Thanks
Many Thanks
17 years 3 months ago #24539
by ramasamy
Replied by ramasamy on topic Re: How to configure Cisco IOS DHCP for per VLAN basis?
Creat a VLAN interface in the core switch and assign the proper IP address from the subnet for all the VLAN interface.
use the ip helper-address command as ip helper-address 1.1.1.1 (1.1.1.1 is the IP address of the Router in which DHCP is enabled)
interface Vlan200
ip address 172.23.93.2 255.255.255.224
interface Vlan201
ip address 210.5.76.242 255.255.255.240
You need to create the DHCP scope for the below mentioend subnets in the Router where you have enabled the DHCP service.
192.23.93.0/27 and 210.5.76.240/28
interface Vlan200
interface Vlan201
