NFS - Network File System OSI layer
- skepticals
- Elite Member
17 years 7 months ago #23171
by skepticals
NFS - Network File System OSI layer was created by skepticals
I have seen the NFS listed as both at the application layer and a session layer. Would i simply consider this at application layer?
17 years 7 months ago #23173
by toddwoo
Replied by toddwoo on topic Re: NFS - Network File System OSI layer
Its application in my book.
- skepticals
- Elite Member
17 years 7 months ago #23174
by skepticals
Replied by skepticals on topic Re: NFS - Network File System OSI layer
Haha, good enough for me.
17 years 7 months ago #23175
by Smurf
Replied by Smurf on topic Re: NFS - Network File System OSI layer
According to the oracle of all that is TCP/IP (i am of course referring to "The TCP/IP Guide", its says that NFS is all three layers of the OSI model (Session through to Application) but if you are looking at the TCP/IP Model, then its just Application because within the TCP/IP Model it wraps the top three layers into a single Application Layer.
It also goes a step further into defining the different functions of NFS that fits in each of the 3 OSI layers;
Application Layer - NFS Procedures and Operations which are tasks that are carried out on the files over the network.
Presentation Layer - XDR (External DAta Representation) allows data types to be defined in a consistant manor.
Session Layer - RPC (Remote Procedure Call) used to implement client/server internetworking functionality.
- skepticals
- Elite Member
17 years 7 months ago #23187
by skepticals
Would a question be asked on the CCNA regarding which layer of the OSI model does NFS function? If so, I would still use application because I should use the highest layer at which a protocol functions?
17 years 7 months ago #23192
by Smurf
Hmm, i think if that question came up then i would have to say the same but you are able to comment and just quote the TCP/IP Guides response, lol
