Network Documentation
17 years 9 months ago #22305 by skepticals
Thanks for the information. I will look into Zenoss.
17 years 9 months ago #22307 by toddwoo
Replied by toddwoo on topic Re: Network Documentation
Most of the config is via the config files and requires you to format it perfectly
There is a tool out there to help with the files.. But for the life of me I can't find it anymore.
17 years 8 months ago #22495 by BruceGE
Replied by BruceGE on topic Re: Network Documentation
I have been doing network documentation for several years I Netviz is our 'defacto' standard. Netviz is a very good tool for network documentation, there is a somewhat steep learning curve because netviz is very feature rich. www.netviz.com .
You can get a free demo down load of netviz from their website, they are located in Gaithersburg, Maryland and I believe they presently are a CA subsidarity
I have also used Visio, AutoCad, Corell Draw, but for network drawins, Netviz can't be beat
17 years 8 months ago #22499 by skepticals
Thanks Bruce, I will look into it.
17 years 5 months ago #23507 by KiLLaBeE
Replied by KiLLaBeE on topic Re: Network Documentation
Skepticals, did you find something?
I was able to document my network's topology and computer-specific configuration with a mind-map.
17 years 5 months ago #23511 by skepticals
Not really, what is mind map?
