Diff between Bridge n Switch?
21 years 1 week ago #1995 by match80
Whats the difference between a Switch and a Bridge?
21 years 1 week ago #1998 by Dudbolt
Hope this helps.....
Generally, a bridge has only two ports and divides a collision domain into two parts. All decisions made by a bridge are based on MAC or Layer 2 addressing and do not affect the logical or Layer 3 addressing. Thus, a bridge will divide a collision domain but has no effect on a logical or broadcast domain. No matter how many bridges are in a network, unless there is a device such as a router that works on Layer 3 addressing, the entire network will share the same logical broadcast address space. A bridge will create more collision domains but will not add broadcast domains
A switch is essentially a fast, multi-port bridge, which can contain dozens of ports. Rather than creating two collision domains, each port creates its own collision domain. In a network of twenty nodes, twenty collision domains exist if each node is plugged into its own switch port. If an uplink port is included, one switch creates twenty-one single-node collision domains. A switch dynamically builds and maintains a Content-Addressable Memory (CAM) table, holding all of the necessary MAC information for each port
Db.
21 years 1 week ago #2016 by sahirh
Dudbolts answer is spot on, if you want some more info you can hit this page :
www.firewall.cx/switches.php
Just remember.. switch - smart... bridge - dumb. j/k
20 years 11 months ago #2120 by nubs
I have been told that bridges connect LAN segments of dissimilar protocols where as switches do not.
Example:
You can use a bridge between an ethernet and token ring but switches cannot..
Is this true?
20 years 11 months ago #2121 by tfs
There are 2 types of bridges: tranparent bridges and translating bridges.
Transparent bridges move data between 2 LAN segments that are the same.
Translation bridges move data between dissimilar LAN segments (such as Ethernet and Token Ring).
A switch is a multi-port switch. Normally doesn't do any translating (however, I do believe there is such a thing as a translating switch, but I've never seen one).
Tom
20 years 11 months ago #2283 by abdulla
hi friends :P
A bridge is an internetworking device used to contact separate LANs or link two network segments, and to filter information between them as well as traffic collisions, and other networek problems. A switch is a network acces device that provides a centallized point for LAN communications,media connections and management activities-like Hub.
regards :twisted:
abdulla.C.A
Time to create page: 0.133 seconds
