Define Cisco Catalyst
18 years 3 months ago #19272 by jtartist
What's the difference between a "Catalyst" and not catalyst unit? And what does "XL" mean at the end of some devices?
You can tell I'm new to this stuff....
Thanks!
JT
18 years 3 months ago #19281 by TheBishop
Replied by TheBishop on topic Define Cisco Catalyst
As far as I know 'Catalyst' is just the name of a particular product family within the Cisco portfolio. I don't think it has any technical significance
18 years 3 months ago #19284 by eylli
Replied by eylli on topic Define Cisco Catalyst
as far as I know catalyst switches are the product line that was continued to be produced by Cisco after Cisco bought the company that produced Catalyst Switches that at the time speakinf ran CatOs. Cisco modified and made possivbe to run Cisco IOS on them.
Hope it helps
18 years 3 months ago #19298 by jtartist
Replied by jtartist on topic Define Cisco Catalyst
Yes it does, thank you both.
JT
