NIC
19 years 9 months ago #18718 by Vilasini
NIC was created by Vilasini
Is there any different states for Network Interface Card? & What is the algorithm used in NIC to avoid collisions?
19 years 9 months ago #18722 by S0lo
Replied by S0lo on topic Re: NIC
The only two states I know about are "promiscuous mode" and "non-promiscuous mode"
promiscuous mode allowes an interface to capture frames not destined to the it's own MAC address. In other words a host on promiscuous mode can take all the frames that passes through up to the Application layer, so sniffer sofware can view them.
Normally a host is on "non-promiscuous mode" so it can only see it's own traffic (frames that have the source or destination MAC the same as the host interface). Surley it can see broadcast traffic too.
On the other hand, A router interface has to be on "promiscuous mode" as far as I know.
Experts, Please correct me if I'm wrong.
19 years 9 months ago #18723 by Smurf
Replied by Smurf on topic Re: NIC
Hi S0lo,
You are quite correct apart from the router part. I am pretty sure that the router still doesn't operate in premiscuous mode, simply because it would need to process every packet for that subnet which is unnecessary unless its a packet that needs to be routed.
I machine will check (using the subnet mask) to see if the packet is for its own subnet or needs to be routed. If it needs to be routed then it will send a unicast packet to the router using the routers MAC address, then the layer 2 MAC information is stripped and the next hop will be added to be routed onwards.
Etherent uses the CSMA/CD to detect a collision on the wire and then it will use a backoff algorithm to then make the two hosts that collided on the wire wait until it tries again.
19 years 9 months ago #18725 by TheBishop
Replied by TheBishop on topic Re: NIC
For a discussion of CSMA/CD have a look at www.firewall.cx/ethernet-media-access.php
19 years 9 months ago #18726 by S0lo
Thanks Smurf :) Yes, I forgot that the router does not need to see frames destined to other MACs in the same subnet, it only needs to route traffic that wants to go to another subnet, and that traffic surley has the MAC of the router since the router is the gateway.
19 years 9 months ago #18727 by Smurf
Although a bridge will forward all traffic, however it will only do this on Layer 2 and not pass any traffic further up the layers as bridges are not layer 3 aware.
Time to create page: 0.103 seconds
