Router interface questions
19 years 9 months ago #18703 by Smurf
Hi Brandon,
Hehe, been watching your other posts about this question :)
Don't get confussed between the Ethernet and Serial. Generally you are looking at the Ethernet/FastEthernet/Gigabit/10Gigabit interfaces are for Ethernet (LAN) traffic. Thats dealing with the Ethernet Frames.
Serial interfaces you are generally looking at WAN, Point-to-Point (point-to-multipoint if using logical) traffic which is either circuit-switched or packet-switched. You are looking at things like HDLC, PPP, Frame-Relay, ISDN, ATM, X.25 etc...
As you can see, its a different kettle of fish really.
Hope it helps you understand the difference between the interfaces on your 2501. As you said in the other post, you can setup a serial link between your two 2501, you would generally use PPP encapsulation (or HDLC which is Ciscos Propriatry) for the link which is point to point.
Wayne
19 years 9 months ago #18733 by Brandonh
Replied by Brandonh on topic ethernet interface
So could you use the ethernet interface as a wan then ? to connect to another router that had internet or a modem that has ethernet port? the interfaces then are not wan and lan but are whatever you make them ? they are serial and ethernet interfaces not necessarly either wan or lan ?
Time to create page: 0.085 seconds
