supernetting question
18 years 6 months ago #17378
by gwydion
supernetting question was created by gwydion
hi, I need some help with a problem involving supernetting. If I have 2 companies and one of them has 10 departments and a class C address 195.78.63.0 and the other one has 10 contigous class C addresses starting from 195.78.64.0, how do I create a supernetting chemem for these 2 companies? I am confused because I am nost sure if the 3rd octed of the starting address has to be divisible by 2 or by 19 in this case. And what role do the 10 departments of the 1st company play for the supernetting scheme? Thank you.
18 years 6 months ago #17405
by Dove
Dove
Replied by Dove on topic Re: supernetting question
Hi gwydion,
you havnt mention how many systems will be in each department. ok as for 10 department you can use the following supernatting.
255.255.255.240
it gives 256-240=16-2=14 subnets each subnets having 14 host IP address....
so the 1st subnet IPs are 195.78.63.0 -195.78.63.15
2nd subnet IPs : 195.78.63.16 - 195.678.63.31
3rd Subnet IPs : 195.78.63.32 - 195.78.63.47 etc...
like this you may create the suprenat for other IPs too..
Hope it will help you
255.255.255.240
Dove
18 years 6 months ago #17453
by zenzippy
Replied by zenzippy on topic Re: supernetting question
Hi gwydion,
company A
the one with 10 departments wil have a summary address of
195.78.63.0/24
Company B
you say they have 10 contiguous class c address 195.78.64.0 to 195.78.74.0
this can be summarized as 195.78.64.0/20 this will be seen by company A's router as one big supernet of 195.78.64.0/20
the mask of /20 will summarize upto a block of 16, so 195.78.64.0 to 195.78.79.0
well thats how I understand it.
company A
195.78.63.0/24
Company B
18 years 6 months ago #17454
by zenzippy
oops, just realized these are not private address so maybe a block size of 8 would be a better answer.
18 years 6 months ago #17476
by Smurf
Thanks for that answer, i was struggling to see how you could fit just upto 195.8.74.0 range and thought you would have to go beyond it. Glad i was on the same wave length.
Replied by Smurf on topic Re: supernetting question
Hi gwydion,
company A
195.78.63.0/24
Company B
18 years 5 months ago #17567
by Dove
Dove
Hi Zenzippy,
How you applied block size 8 for your requirement. you said you need 10 IPs for each dept know then how come.
The possiblity is either you can use the block size 16 and above only.
can you tell me how you subnetted.
Dove
