Lan setting to allow Wan access?
21 years 9 months ago #170
Lan setting to allow Wan access? was created by Chris
Jkcm,
Your question is not clear, can you re-post it and also provide more information on what exactly you need to do?
It would be a good idea to also include the make and model of the router you are using, just in case someone happens to have the same router and can help you with it.
21 years 9 months ago #169
by jkcm
Replied by jkcm on topic Lan setting to allow Wan access?
Recently, I have brought a router and I can access my computer (Lan:192.168.x.x) via other computer (Wan: public IP). What settting do i need to configure? Can anyone help?
