installation
18 years 7 months ago #16560 by satts
installation was created by satts
Hello guys have a quection......
Lets say i have two drives in my hard disc c: and D: have formatted using NTFS .... now can i have two OS in two differnt drive 98 and xp
18 years 7 months ago #16562 by taqqi14
Replied by taqqi14 on topic Re: installation
win98 u cant ...it cant read NTFS filesystem....XP u can....
tell me if i m wrong :)
taqqi
18 years 7 months ago #16563 by Arani
Replied by Arani on topic FAT and partitions
hi,
if you partition the different logical drives into NTFS and FAT16/32, then you will be able to install XP on the NTFS logical drive, and Win98 on the FAT16/32 logical drive. but not the reverse.
have you decided what you want to install on your primary partition. you can keep your primary partition i.e. your C drive as NTFS and install WinXP on it, and format your D (logical drive) as FAT32 and install Win98. make sure your MBR displays both OS as options when your computer is loading up.
18 years 7 months ago #16582 by Smurf
Replied by Smurf on topic Re: installation
Why do you need the dual boot ? Can you not use something like VMWare or Virtual PC/Server to install your Windows 98 install on ?
