Solid Vs. Stranded UTP cable
18 years 8 months ago #15785
by jtartist
Solid Vs. Stranded UTP cable was created by jtartist
What's the difference between solid and stranded cat5e-6, etc cable? What does each of them look like and what's the purpose of each? I've searched online but the information I've found is unclear. I guess one is used for patch cables and the other isn't...?
Thanks!
Thanks!
18 years 8 months ago #15804
Replied by TheBishop on topic Patch cables
That's basically it; the solid cored cable is used for fixed wiring and the flexible is used for patch leads which have to cope with movement without breaking
18 years 8 months ago #15814
by jtartist
Replied by jtartist on topic Re: Solid Vs. Stranded UTP cable
Thanks for the reply.
What's the physical difference between the two? I've noticed on some UTP cable a crossed rubber component running parallel and seperating each of the pairs of wires, is this the solid type?
18 years 8 months ago #15828
The difference is in the physical construction of the copper conductor itself. If you strip the end of the cable, separate the conductors and bend one you'll see. In a solid cored cable the core will stay bent and feel rigid. In a patch lead they are more floppy.
The non-conducting internal components you mentioned are there to maintain the electrical and physical characteristics of the cable along its length. These vary from manufacturer to manufacturer. Sometimes you'll also see a nylon thread or string, and there may also be talcum powder
