LAN configuration
19 years 2 weeks ago #13990
by nkjose
LAN configuration was created by nkjose
Hi folks
Facing some problem with my LAN. I am trying to isolate a computer from the LAN. The problem is that I would like this computer to remain connected to the internet without being on the local network. Is it possible to do this?
My setup is as follows:
A D-link 502T DSL router connected to a 10Mbps 8 port ethernet hub. There are four computers on the LAN: 3 win98 computers and 1 windows XP computer. I am trying to isolate 1 win 98 computer from the LAN without disconnecting its internet. Wonder if it is possible to do so with this DSL router.
Thanx to all
Nitin
Thanx to all
Nitin
- tHe-SwItCh
19 years 2 weeks ago #13991
by tHe-SwItCh
Replied by tHe-SwItCh on topic ok ...........
hi
the 502T, as per my understanding, does not impose access rules amongst LAN clients and hence ur proposal to isolate a single PC on the LAN is not possible. The access/ denial rule implementation ... like in m0st SOHO devices ... only for LAN to WAN and WAN t0 LAN access.
U may hv the reverse happen though .......... by allowing that PC to connect to all other LAN components but disallowing it access online !
Cheerz n beerz
Cheerz n beerz
19 years 2 weeks ago #13995
by DaLight
Replied by DaLight on topic Re: LAN configuration
If as tHe-SwItCh says, you find out that your router will not do what you want, you could install a software firewall like
Zonealarm
and configure it to prevent all communication with your LAN.
- kunaltyagi
- Junior Member
19 years 1 week ago #14099
by kunaltyagi
I'm an artist by living --- my art is my life
Replied by kunaltyagi on topic Re: LAN configuration
u cannot disconnect it from the LAN if u want it to be connected to internet ... however u can always set the restrictions on ur router where in u can stop the LAN communication with that PC and allowing it still to access the internet functionality.
- tHe-SwItCh
19 years 1 week ago #14118
by tHe-SwItCh
Replied by tHe-SwItCh on topic hmm .... thoughful !
I m afraid Kunal .... what you say is not a possibility with the specific unit our friend's got .... most SOHO routers do not excercise firewalling/ ACLs for LAN to LAN traffic, but only for LAN to WAN and vice versa.
As Light sez .... a s/w firewall is the solution ..... but rules need to be carefully excercised under the firewall's Administrative Login so that users on the Individual system do not manipulate settings.
Cheerz b beerz
Cheerz b beerz
