Abt Interface Connection
19 years 1 week ago #13982 by ccnx
Hi All
Can any1 tell why a crossover cable is used to connect a PC to router or Switch to hub??? Based on my home network experiences, i currently use connect my pc to my 4 ports SMC router using a straightthrough cable without any problems. however, since i studied the CCNA material, i had found that the description on the interface connection is different from me!!!
Use crossover cables for the following connections:
Switch to switch
Switch to hub
Hub to hub
Router to router
PC to PC
Router to PC
19 years 1 week ago #13985 by TheBishop
Have a look at www.firewall.cx/ftopict-1845-crossover.html in the first instance, and feel free to come back if you have any more questions
19 years 1 week ago #13989 by Arani
Replied by Arani on topic good start point
yes that is a good point to start from. you see, some devices does the x over withing themselves and some don't. so it all depends on whether both end devices support internal cross over or not.
but still, go ahead and give the article a read.
19 years 1 week ago #13998 by The_Berzerker
Just to note that you do not connect your PC to the SMC router but to the switch that is implemented with the router... :wink:
19 years 5 days ago #14098 by kunaltyagi
it works most of the times however what u read in the CCNA materials are the recommendations about the product ...
and it's always advised to take the medicine from a doctor rather than a pharmacy shop
I'm an artist by living --- my art is my life
19 years 3 days ago #14161 by TheBishop
Replied by TheBishop on topic Crossover
Agreed. Although auto-crossover seems like a great feature, not all devices do it properly and I've actually measured inferior throughput with an auto-MDIX'd link compared to using the same two device ports with the correct cable so that the auto crossover is not necessary
