Cisco 837 Router setup problems
19 years 2 weeks ago #13850
by oliver
Cisco 837 Router setup problems was created by oliver
Hi
I have just aquired a Cisco 837 Router and am having problems configuring it.
At the Web Setup utility I enter all the required info i.e. user name password, ip addresses etc and click apply. i then get a message box with status bar saying the settings are being sent to the router. However this process does not seem to work as the status bar and message box stay on screen for hours and the settings do not seemed to have been sent to the router.
Has anyone experienced this before or can help me?
19 years 2 weeks ago #13861
by havohej
Replied by havohej on topic Re: Cisco 837 Router setup problems
maybe the java stuff, try upgrading as some sdm dont works with old java software.
- CaptainCodfish
19 years 12 hours ago #14267
by CaptainCodfish
Replied by CaptainCodfish on topic Same here
I am having exactly the same problem.
I reset my 837 to its factory defaults yesterday after my telephone had been down for a few hours.
Now It will not accept any of my details. I am using my old netgear 834 as that is simple but does not stay up for weeks on end like my Cisco837 did. I am using the same version of Java I had when I originally set up the 837 have uninstalled adwatch and McAfee. I would really like to know why my settings are not being held.
18 years 11 months ago #14297
by jwj
-Jeremy-
Replied by jwj on topic Re: Cisco 837 Router setup problems
I think the web interface is just buggy in general, just use the CLI. I've been having problems with the 1310 AP's web interface, so I think this is a pretty common problem.
-Jeremy-
- CaptainCodfish
18 years 11 months ago #14298
by CaptainCodfish
Replied by CaptainCodfish on topic Fixed it
I spoke to a chap in the office who has had problems with this sort of thing before. He recommended using a different PC to do the config. 3 PC's later and 20 minutes every thing is as it should be. I am a little concerned that if I didn't have a few machines to hand how I would have got around this. But I am happy for now, now that all is working.
