CAT 3550 - copy flash tftp problem
19 years 1 month ago #13655
by johnnymac
thanks for this, could you tell me how i would go about doing this.
Regards
J mac
Kind Regards
J Mac
Replied by johnnymac on topic Re: CAT 3550 - copy flash tftp problem
try copy the hole directory to a tar file on the tftpsever. Coping only the bin image doesnot archive the htm files that give hte possibility to manege the switch from the web and doesnot allow to build a switch cluster. the comand to archive the cisco software on the new swithches is "archive upload sw ..... "
Regards
J mac
Kind Regards
J Mac
19 years 3 weeks ago #13751
by eylli
Replied by eylli on topic Re: CAT 3550 - copy flash tftp problem
archive upload-sw /? and you will see the options of the command
regards
regards
19 years 3 weeks ago #13752
by eylli
archive upload-sw ? sorry
19 years 2 weeks ago #13777
by meisiew
Replied by meisiew on topic Re: CAT 3550 - copy flash tftp problem
Johnny, 2 options copy/archive. There is missing command "flash" on the source filename line -- see the e.g. below
Switch-A# copy flash tftp
Source filename []? flash:c3550-i5k2l2q3-mz.121-13.EA1a/c3550-i5k2l2q3-mz.121-13
.EA1a.bin
Address or name of remote host []? 192.168.1.10
Destination filename []? c3550-i5k2l2q3-mz.121-13.EA1a.bin
If you need the details, pls refer to book.itzero.com/read/cisco/0512/Cisco.Pr...00/ch10lev1sec5.html
Hope the info helps
.EA1a.bin
Hope the info helps
