Is my understanding right...
19 years 1 month ago #13479
by Jiggy
Is my understanding right... was created by Jiggy
I know that T568A and T568B are just two of the many wiring standards, now, am I right in thinking that if I wire a Cat5 cable to RJ-45 plug using T568A at both ends I`ve made myself a straight thru/patch cable ?
And T568A to T568B makes a X-over cable ?
Thanks.
Thanks.
19 years 1 month ago #13484
by jwj
-Jeremy-
Replied by jwj on topic Re: Is my understanding right...
Yes, you are correct. The termination wiring is only one part of the EIA/TIA standard, but the rest of the standard is mostly specifications on structured cabling.
-Jeremy-
19 years 1 month ago #13486
by Jiggy
Replied by Jiggy on topic Re: Is my understanding right...
Thanks lad, I can carry on reading the rest of the Networking part of this site now.
- tHe-SwItCh
19 years 2 weeks ago #13879
by tHe-SwItCh
Replied by tHe-SwItCh on topic Hi mate
Could you possibly direct me to some good online tutorials and/or demos that would help a noob understand the basics of cable crimping n the subtle art involved ? Something that that is grounds up and with pics would more than suffice
Regards
Regards
19 years 2 weeks ago #13880
Replied by TheBishop on topic Making Cables
www.lanshack.com/make-cat5E.aspx
is what you're looking for
