Pro's/Con's of interface vs IP for static routes
19 years 3 months ago #12514
by drizzle
Pro's/Con's of interface vs IP for static routes was created by drizzle
Static routes can be defined by interface or IP addr. What are the pros and cons of using each? I have seen examples of static routes using both techniques but is there a rule of thumb as to when to use an IP and when to use the Interface?
- naughtypaul
- Junior Member
19 years 3 months ago #12518
by naughtypaul
NaughtyPaul
Replied by naughtypaul on topic Re: Pro's/Con's of interface vs IP for static routes
Hi
Using the interface is more preferred over using the IP address because there could be instances were you may change the subnet / IP in a network segment. In such scenerios you can keep the routing table untouched since its the same interface connecting to the destination / route to destination.
Paul
Paul
NaughtyPaul
19 years 3 months ago #12568
by drizzle
Replied by drizzle on topic Re: Pro's/Con's of interface vs IP for static routes
I figured that was the case. I guess it could equated to specifying nodes by hostname vs ip. Sometimes its better to use hostname and other times by the ip addr.
Thanks!
Thanks!
