dansguardian, squid and iptables
19 years 4 months ago #12042
by monsky
dansguardian, squid and iptables was created by monsky
hello there, what should be the syntax in iptables if i have dansguardian and squid? ive been figuring this out for how many days now and everytime i did redirecting the port 3128 (port of squid) to port 8080 (dansguard) i could not browse the internet. with the port 3128 all works fine. but when i redirect the 3128 to 8080 i couldnt browse the internet. eth0 in the internal network and eth1 to the internet.
can somebody give me the idea how to fix this?
thnx again in advance
19 years 4 months ago #12045
by DaLight
Replied by DaLight on topic Re: dansguardian, squid and iptables
Did you use the following command?
[code:1]iptables -t nat -A PREROUTING -i eth0 -p tcp --dport 3128 -j REDIRECT --to-port 8080[/code:1]
Let us know if it works.
19 years 4 months ago #12100
by monsky
Replied by monsky on topic Re: dansguardian, squid and iptables
thnx Dalight,
yes i did what you had suggested. but was it right that i first redirect the port 80 to 3128 (squid) then redirecting the 3128 to 8080 (dansguardian) ?
iptables -t nat -A PREROUTING -i eth0 -p tcp --dport 80 -j REDIRECT --to-port 3128
19 years 4 months ago #12101
by DaLight
No just use the line I gave you and set the Proxy to Transparent mode.
19 years 4 months ago #12192
by monsky
tnx DaLight. problem solved.
