What is Ip forwarding?
19 years 4 months ago #11922
by Lindows
What is Ip forwarding? was created by Lindows
Hey Guys,
i built a ip cop box, thanks to Dalight and the others. I finally logged into my router through the web interface (browser) and i came across an option called ip forwarding. Whats is it for?
Lindows
Lindows
19 years 4 months ago #11923
by DaLight
Replied by DaLight on topic Re: What is Ip forwarding?
Glad to hear your IPCOP's up and running, Lindows. I don't actually think IPCOP has got an IP Forwarding option. You may be referring to the "Port Forwarding" Option under the "Firewall" Menu. This screen allows you to redirect any packets which hit your firewall's external interface to selected machines within your network. The basis of selection is by TCP or UDP port. For example, if you have a web server behind your firewall, you would redirect port 80 to the IP address of the internal web server.
IPCOP also allows you to handle more than one IP address on your external interface using the "Aliases" option under the "Network" Menu. Once these have been set up, you can also forward specific ports using the "Port Forwarding" Option.
